- Wed Apr 08, 2015 9:09 am
#46135
Hi Jack... yes, the fuel pump is operated through one of the relays. Not sure if it is a direct connection (Thack will know as he has made up a good wiring diagram in the past) but direct or otherwise, a sticky/blown relay could result in the fuel pump not working.
If the neutral light is going on, but not the MIL and the fuel pump is not priming then that is an important bit of data. It means the problem lies in the ECU circuit primarily. Check relays and fuses as number 1 problem... but also check for some wiring continuity from your ignition barrel to both sides of the relevant fuse (and check for 12V too).
Thack, when you say the 'emergency stop switch' do you mean the rollover sensor under the seat on the right of the ECU? Also, on my own Electra EFI the sidestand switch isolated the entire EFI circuit (i.e. it basically switched the fuel pump off and removed the signal to the ECU from the battery). I ditched the electric start years ago, but I didn't think my bike cranked with the stand down either? Maybe a change has happened... or maybe my memory is gone. Either way, ditch the switch - when it fails you will be getting muddy and oily and greasy in the middle of nowhere in the rain...
