- Mon Oct 27, 2014 12:18 pm
#41128
most companies that do a momentary on, also do a momentary off (usually with a different colour button.)
My suggestion is to route from the positive battery, up to the momentarily off (Push to off) switch, and back down to the points. As long as the switch does not get moisture corrosion over time, it should be ok.
your points would usually be connected to power, until you hold the button in causing the engine to stop. after that of course, with no battery, your system would be dead until starting again.
The only possible drawback is that the wiring and switch are one more thing in the ignition circuit that can potentially go wrong.
Flick your lights on or press either brake after stopping the engine if you want to play with the wiring, as sometimes the capacitor can store some power for a while, and can make you give a 'false smile' when playing with points and coil!
REOC 15084
Tabellarius de verbis. Ostensor gaudium
