By Exile
#33113
Sorry. I couldn't resist a Sooty plug... Izzy wizzy, let's get busy..
#33124
eeeek-------eeek--------------eek,eek----------eeeekk-----------so there !!Image
By Presto
#33136
My bet would be the plug is too 'hard'. In this weather a Bullet (EFI or any other) rarely gets up to temperature for the plug effectively to self-clean. A combination of a too hard plug, cold weather, and 'careful' riding. The plug needs to be around 400 degrees C to 800 degrees C to effectively self-clean. My guess is that isn't happening in this case. (Fuel injected EFIs rarely fail to provide the right fuel/air mixture strength.)
By Franky
#33149
Iv'e changed the plug for a 6 and it is running so much better is getting to be the colour it should be . I have also ordered a 5 and will try that. thanks for all your help, including sooty and sweep ;)
By Jim
#33169
Franky I had exactly the same problem after the original plug failed. I then got a replacement (but different) plug and I checked several times to make sure it was correct. Even Watsonian didn't make any comment about the plug when I phoned them. However, it was wrong and I got the sooties big style. Check, check and check again.
By Dennis C
#33170
Another thing to be aware of, the UK market is currently flooded with counterfeight NGK plugs so be careful where you buy from, don't use too hot a plug as the outcome can be a hole in your piston.
