- Fri Jan 24, 2014 11:42 pm
#32095
Upto the mid 90's they used 5/16" cycle which is 26tpi. After this they changed to M8 x 1.0. The difference is very little 26 threads per inch compared to 25.4 threads per inch and a diameter of 0.312" compared to 0.315". A normal M8 x1.0 nut will probably fit both rods but on a longer nut like the brake rod adjusting nut the thread will bind if you get it wrong.
JT
JT
