- Fri Jun 21, 2013 11:31 pm
#26014
I read an article recently that says if you want to upgrade to 12 volts that by fitting a 12 volt rec reg unit to a 6 volt alt it will charge 12 volts. I might have to go back and re read the article and take it in properly. Does anybody know what A/C voltage I should expect from a 6 volt alt, similar to a 12 volt alt? 30 volts A/C? If this is the case I still don't understand how this coil switching operates, is it done through the headlight switch? and if so how does it do it?
