#23118
Hi ZIPPY-------- I should have put the name in "-------" as I meant it in a generic sense.. I usually get my stuff from Stafford (or the like) at £5 for 5 tins -- and they're bigger than (shhh!, you know what !!)--- and smell nicer too !!
By zippy
#23120
I'm a 3in 1 man myself.it's the bikers aloe vera, - cures all :D :D
By jaffa90
#23123
WD40 is a penetrating oil,viscous oil.I use it to prevent rust which is common on enfields.
#23124
Zippy,
I used WD40 on my Inter gauges when I had the glass off, wiped the grey face with it and it restored the colour back to original made them look new again and has been that way for a few years now
By Howzie
#23130
Hello one & all, Many thanks for all your help & tips, great stuff that's what I like about this site fantastic.
Cheers.
By Gwilly
#23131
Taken from wikipedia re WD 40.
NORM LARSEN sold WD-40 and Rocket Chemical in the early-fifties for a mere $20,000 (no royalties, no residuals, as he believed he would always be able to invent something better), to Sam Crivello, Gene DeFalco, and two others................oh bollocks.
By Jack
#23135
Wouldn't you be able to do this in situ,by removing the tyre and tube then replacing it and spin it from there on the forks?jack.
By John L
#23136
WD40 is wonderful stuff for what it's designed for - displacing moisture......
It's next to useless as a penetrating oil, and not very much better at lubricating......
Just my 2p's worth..................
#23151
Hi guys----------- JACK, it's actually better to balance the WHOLE tyre,wheel assembly as a complete unit just after a new tyre has done its' initial 100 miles or so of "scrubbing-in"... Just a point of note}---- if you do your own tyre changes, most manufacturers will have pre-balanced a new tyre with a coloured dot of some description (red or yellow seems favourite)---- this will indicate the LIGHTEST POINT and should be placed alongside the valve...Have a good look at this Dunlop Fact Sheet }--- http://www.dunlop.eu/dunlop_euen/mc/tyres/tyre_care.jsp --------------------
By Jack
#23156
AlanR,we had moved on from balancing to truing the rim,so that's what i was describing.
