- Sun Dec 30, 2012 10:31 pm
#21099
I use LEDs in my work as a lighting engineer. For vehicles they work very well when part of an OEM design but as retrofits I find that LEDs polar curve (direction of light intensity) is too different from conventional filament lamps to work correctly in most of the light fittings on a bike - panal, meter and position lamps largely excepted if the LEDs have been chosen carefully.
Obviously new designs are being introduced all the time, but again (as Bertie said) the AC generator output on a Bullet can cause problems (particularly) with higher power LEDs, which mostly require a DC constant current supply.
Norm, 60 years without an MOT? I can't get my head around that. Either way, yes the LED lamps may light but the beam pattern will be most unsatifactory, unfortunately.
