By Paul
#20408
Hi,
I haven't done a conversion but I've ridden a few.
I suggest you ride one first to know what you are getting. It's not just a difference in maximum power.
cheers
Paul
By Wiseowl
#20425
Hi, I haven't done a conversion but I've ridden a few. I suggest you ride one first to know what you are getting. It's not just a difference in maximum power. cheers Paul
Code: Select all
Which leads on to the obvious question, is there a diesel conversion in South Wales that I could have a look at, and maybe a ride?
Cheers
Martin
By grunda 12
#20433
hi wise owl ,wise words from paul ,diesel enfields are not for the masses ,if you like to ride a bike flat out all day this is for you ,i,ve screwed the nuts off mine for 5000 miles and still returned 160 to the gallon ridden at a steadier pace my colleague kevin who has the same style conversion as mine gets around 180 /200 mpg,the conversion is straight forward i used salad oils spacer with a 70mm id !!the engine is not quite central although this is not noticed when riding,i used all the standard primary i found no need to use a lengthened gearbox shaft although thats up to you ,henry price sells converted bikes for 4k he also sells all the conversion parts ,i must say i made everything except the fan cover and the taperlock sprocket /engine, my bike runs a straight through plant style exhaust which terminates under the engine very industrial,anyway this diesel thing is quite an exclusive club so come and join us if you can cut the cloth!! atb paul.
By grunda 12
#20434
just thought of a little more in fo if converting a 350 bullet as i did you go up a road tax bracket ,when youve done your conversion get it inspected at your local mot centre,get them to verify the changes on letterheaded paper the dvla have a thing about engine numbers,insurance wise its classed as a modified bike it costs me 135 quid fully comp ,on the log book it says heavy oil under fuel ,model bullet 350 ,cc406 so there you go a complete minefield have fun ,atb paul.
By MadMike
#20436
Paul I didn't know you had a diesel thingy. I thought that the rattly old thing you brought to Madmikes Gathering was just a regular Royal Henfield. A Diesel. Well I never. Isn't that amazing. You learn something every day. Yes I know....hat....coat head for the door. Hee hee hee.
By grunda 12
#20444
i,d love to post some pics but not being a computor genius i.m not sure how ,CANAL BARGE!indeed mr tindal i liken it to a cement mixer without an exhaust on !!make up your own mind if you see me in 2013 i get out and about on it all over the country ,will be at mad mikes gathering when its on ! atb paul.
