- Mon Oct 15, 2012 5:40 pm
#18566
Hi Symon. One of the old inner races on my crank just slid of without applying any force, and the other wouldn't budge. I tried like you to lever it off using the small gap behind the thrust washer, but wasn't successful, and in the end my employer, who has a motorcycle workshop helped me out by applying two spots of weld to the inner race so a puller tool he had could get some grip and finally yank it off. I reused my old crank and had it carefully rebalanced. I bought two new thrust washers from our hosts. They do not feature in the parts manual, and I had to phone them. Apparently they have access to a slightly more comprehensive version, which also covers the parts not listed in the regular manual. I've just checked my receipt, and they are part number 140799.
One of the new main bearing inner races was too loose, as it could swivel around on the shaft. As previously mentioned, Locktite 648 sorts this problem. The other was too tight a fit, and Norm advised me to heat it up before sliding it on. I heated it up with a heat gun, but it cooled down again really fast and got stuck half way down the shaft. I improvised a rig to hold the crank upright, sanded a block of wood down to fit between the flywheels and by repeatedly reheating the inner race and knocking it down by placing slightly larger inner races of old bearings on top and using a block of wood and a hard rubber mallet, I finally got it into place. I'm not happy I had to bodge this inner race on my newly rebalanced crank in this manner, and would do it differently if I got a second chance! I might even be tempted to sand the shaft down with sand paper, using the wrap-around method. Hope yours are a better fit.
Sorry if I've repeated myself, but I wouldn't like you to face the same problem!
Good luck.
