....well, after getting an old bullet in my garage still having the german technical inspection tag beeing good for this season..... i built the engine in that bike and checked all the things i need for testing. Brakes, wheel bearings, gearbox with 20-teeth sprocket, good clutch and working suspension..... all these things had to be repaired...
Last not least i managed to have the engine running. I didn`t fix the whole electric..., since i can drive with a big battery for testing purposes...
https://youtu.be/ybfx6k7gUg4
>> and i did my first test ride...! That engine is really pulling from low revs on.
I didn`t try any higher revs than maybe 1.800... So i can say so far, this engine is working..!
@Vince2: You may (after initial running in) run that engine over 3.000 revs... and it may run with 3.500 revs for a while.... but than the speed of the piston will be to high.... and the heat will be to high.... and the engine will... ups...
