#92538
Are they better? I dunno.
What I do know is there's a lot of money spent needlessly replacing sparking plugs.
I have quite a few engines (some 2 strokes) that haven't had a plug changed in ten years.
All I can say is what I said before - I tried one as a slightly extravagant experiment because I felt my bike probably needed a new plug to make the idle more reliable (it has TCI ignition so probably has the ability to produce a very good spark anyway). It has unexpectedly improved the bike's running all round. Hopefully I'll not have to buy another plug for a very long time, if ever.
By Nitrowing
#92550
PeteF wrote:
Fri Aug 28, 2020 7:40 am
I can't remember the last time I've had a spark plug cease working.
I also have a sneaky suspicion that if people had just put a brand new 'normal' plug in it would have felt better anyway ;)
Possibly but the effect was noticeably more marked than the when I changed the plug the previous time. I think this is a case of “don’t knock it till you’ve tried it”.
By Cranky
#92658
Its all in yer ead .
Some psychological experimentation needed here perhaps washing the bike might help you. Ive heard it does.
Maybe a quartz headlamp can pierce the way in the dark not to mention the plethora of fuel additives .
Its all in yer ead Wallace.
By Nitrowing
#92661
A dyno run would show the efficacy of an iridium plug.
Run with plug with over 5000 miles use.
New standard plug.
Iridium plug.
Cranky wrote:
Tue Sep 01, 2020 3:22 pm
Really? I take it that you already tried one and found no difference.
I’ve enough experience to sense what’s snake oil and what isn’t. ;)
Btw, you’ve been on the forum just two weeks and your post is offensive.
By trophyvase
#92669
What a strange line of thought this thread has produced!
By the nature of the case a spark plug of itself cannot increase power. It provides a spark. That spark may be weaker or stronger – either way a spark causes combustion of the fuel charge. The spark cannot determine the power produced by that combustion. The potential of combustion is affected by volumetric efficiency and/or thermal efficiency. Neither of which are affected the type of spark plug - so long as the spark plug sparks!
