Wheaters wrote:
Thu Jul 16, 2020 6:52 pm
Mater? I wish my late Mum had owned a fast bike!
But you wrote “HE”. ....Is that why it’s called a drag bike?
:D
Fat finger typing...
stinkwheel wrote:
Thu Jul 16, 2020 11:12 pm
:D
I suffer from that too, and often I don't notice until I've posted. That's why many of my posts come up as having been modified. :oops:
By Jerseyplym
#91495
I think the requirement for riveted links comes from powerful bikes using o-ring chains (which last a lot longer) because the movement between the plate and pins on the split link can wear and weaken it over time, faster than the rest of the chain. With a properly installed rivet link there is no movement between them.
I have heard they last about half the mileage of the rest of a properly cared for o ring chain, while on a standard chain the rest of it is probably toast before the split link will give up.
If you do use a riveted chain, make sure it's done properly. Too loose is dangerous, and too tight will wreck the o rings and shorten its life.
The proper tools have a guide to make sure it can't be riveted incorrectly.
Personally I fit the split link, ride to the shop and get them to install the rivet link (on a bike that warrants it!)
