- Tue Feb 28, 2012 5:00 pm
#9982
It was definately a problem with drum brakes "back in the day".
You'll notice an air scoop fitted to the front drum on many old Brit bikes. Not at all uncommon for people to drill holes in the brake-plate to allow for better air circulation too.
"Bacon slicer" discs fitted round the outside of the drums were also popular at one point.
The only really useful suggestion in addition to those already given is to leave a bigger gap or go slower.
Actually, that's npot necessarily true. I fitted a span-adjustable, upside-down clutch lever off a late model GPZ500 to my Jawa as a front brake lever (you can even use the clutch idiot switch as a brake light switch) . It made an enormous difference to the braking effectiveness, presumably due to the cantilever action of the lever and the fact it is sat on a bushing.
Regarding hydraulic Japanese disc brakes fading, it is entirely possible to boil them into oblivion if you try hard enough. I have done several times, leaves you with no brakes at all. You just have to stop and wait for them to cool down.
If you want truly apalling brakes, try riding something with the abortion that was the cable operated disc brake, as fitted to the early CB125 twins and the CD200. It doesn't work, right up to the point where it starts binding.
