- Tue Jun 02, 2020 10:01 pm
#90462
Just about every modern bike I've owned in the last ten years has had a forum associated with it and in that forum there has been a thread or two about what oil to use and how to check the oil level. To not buy a particular bike just because (a) it has a sight glass, not a dipstick, (b) it has a dipstick not a sight glass, (c) the reading is taken cold, (d) the reading is taken hot seems to me to be denying oneself the opportunity to enjoy ownership of a great bike. One just has to learn what to do.
Yes, I ordered a pack of doughty washers too; odd that our host sells them. They really are useful. Really it just boils down to reading the owners manual or failing that finding a consistent way of measuring the level and not obsessing about it. These UCE models have many quirks and some weaknesses but generally they don't burn or leak oil. FWIW all I do is drain the oil as thoroughly as I can by leaning the bike on its main stand to the left and right to get as much out as I can. I then add a measured amount of oil as specified in the manual, start the engine, check for leaks then forget it until the next change is due. I know it looks like there's no oil in it if I park it on its side stand, but I don't panic and then overfill it - I've done the same for years on all my bikes that have wet sumps. Two things I would stress about the UCE models are not to use thread lock on the sump bolts as advised in the owner's manual - there's no need and it doesn't help the longevity of the threads - and if it leaks oil after it's been changed don't tighten the bolts beyond the specified torque or, guess what, you'll strip the thread and it may not stop the leak anyway.
