- Sun Aug 19, 2012 8:32 pm
#16409
Hi Sab. You have been busy, and from everything you have written it looks like you have rewired in a manner that will work, as long as there are no hidden incorrectly cross connected wires somewhere....The new wiring might be non standard but it was non standard anyway and is now in its most simplest form which many old bikes used. I guess the wiring from the light switch has been mostly left as it was, as the headlight needs to be powered via the dipswitch and you will also have a position on the lighting switch to switch on the pilot lights, so we will assume they will work as before. The fuse on the negative battery terminal to earth is fine and does not need changing, it does not have to be on the supply side. The rating of 30 amps is also OK, but if you have a 12amp that will fit to start with, might be sensible but not essential, put back the 30 amp one when all OK.... So now switch on and test. The ammeter should show a disharge commensurate with the different loads draining from the battery. If everything works as it should. Start the engine and monitor the ammeter the needle should now move over to the right hand side and show an increasing charge as you increase the revs, untill the battery has charged when it should not indicate not much more than 1-2 amps. obviously if the needle swing is completely in the wrong direction, simply reverse the wires onto the opposite ammeter terminals...good luck
