- Fri Sep 24, 2021 1:34 pm
#98388
Further up Haggis made a good point about float level
Just about level with the pip on the float bowl cover is where you need to be
Well worth checking both carbs
Edit
If you have choke fitted it would be worth trying to see if it will come off tick over with the choke slide dropped into choke position (lever pushed forward to choke )
Very comon problem people have with amal carbs is the choke works opposite to the way you would think
Big edit cheers Dai
Edit
Big edit cheers Dai
Dyslexic sorry folks can't help that
Owner of asbo 30
Please remember most carburetor problems are electrical!
Owner of asbo 30
