- Mon Feb 13, 2012 5:44 am
#9529
Mark, further to Dan's comment on being careful when refitting the timing cover....put the bike in gear and as you tap the cover back with the heel of your hand, turn the rear wheel so that the worm gear gets the chance to mesh cleanly.
Also, since you may wish to remove both cams to check for wear (now that the cover is off), make sure you don't move the crankshaft too much otherwise you'll get the cams back correctly set but the distributor will be out. I have marked the correct setting on all gears with my trusty dremel - do it temporarily with typex/white paint.
Also, as Dan says, you'll get about half a litre of oil out of the chest - feed it back in through the tappet adjuster opening (or preferably down the pushrod tube) after you've replaced the cover so that the pump is properly primed.
ChrisD
