- Wed Feb 15, 2012 2:37 pm
#53
It's on my '07 350 classic which has the standard AC/DC alternator fitted.
I noticed this last night that when I turn on the main headlight, I get a fairly intrusive whirring noise from the vicinity of the primary case. This noise is directly dependant on the lighting switch, it goes away immediately you turn the lights off and is not present with the sidelights on. Sounds a bit like someone winding up one of those dynamo torches.
Now it could be that this noise has always been there and I never noticed before but it does seem new to me. I'll be having a look under there at my earliest convenience to check everything is working ok but it would be good to have any ideas of what exactly I should be checking.
I should add that the electrics all appear to be finctioning normally and the headlight is nice and bright. I'm running ATF in the primary drive and have been for about 15k miles now.
Any thoughts welcome.
Scott
Scott
