#90402
Dear Wise men out there!
I have seen various YouTube clips + have Tech manual - First point of call was tech manual - Find TDC (No Ammeter) so have used a " Laser 2833 Top Dead Centre Indicator " which works well - Manual advises adjust Rockers (0 mm gap) using feeler gauge BUT unless you are a contortionist, really not sure how you can get a feeler gauge angled right to measure any gap! unless of course you remove Petrol Tank but even then can't see how this can be done easily!
So reverting to YouTube Clips showing pushrods being able to spin with no upward movement is the measure!
Currently I have no issues kick starting - but on inspection of Push Rods (Via removal of Tappet Cover )- they are tight (unable to spin) with no slack!
Do I go by YouTube video able to spin with no slack on rod? - Your input and guidance would be very welcome - Thank you.
#90407
Even feeler gauges are too technical for these engines! I don’t know how you can use them to set zero clearance anyway....I’ve looked on my set of feeler gauges and there isn’t one that reads zero thousands of an inch. 🤣
Yes, don’t forget that only “every other” TDC is the compression stroke. Trying to set the clearance at TDC on the exhaust stroke simply doesn’t work.
