By tribonnie
#89619
Hello, can someone please post, or point me to a website showing, a wiring diagram for early 1990’s Bullet that uses the left hand Magura switch. I think these are pre 1996 and kickstart only. Thanks Richard
By black fingernail
#89628
Mine has A Magura switch on it and it is a 1998. I recently re-wired it, but I cannot remember the colours and my notes are not to hand. There is a decent set of diagrams in Pete Snidals manual, but it is quite easy to identify the wires coming out of the switch by just unscrewing the front off, and inside is all to see.
I presume the magura ones are quite simple compared to the AC/DC ones, which are, in the words of Sherlock Holmes, a "two pipe problem".
By PO51UHD
#89638
Hello
I have a ‘93 Superstar and when I rebuilt it I used one of those lh switch thingies. Took me a while to figure it out but I have a diagram.
Email me at stephen(underscore)herbert(at)btopenworld(dot)com and I’ll send a copy.
By tribonnie
#89639
Black Fingernail (nice name)
Figured out most but can’t see haw the “flash” works.
I assume the flash will work without the other lights on
Is is just a simple switch to earth like the horn press
Thanks Richard
By black fingernail
#89656
Thank you kind sir.
There is a wire from the switch directly to the ammeter to power the flash, as well as the feed in to power the lights from the headlight switch, I cannot remember the colours.
If you wire everything else in you will have a spare wire that is the power in to feed the flash.
I hope this makes sense, I need a lie down!
