- Wed Sep 04, 2019 3:46 pm
#85264
I recently acquired a 2009 Electra X in rather good shape but needing some tuneup which I have been working on bit by bit. I am noticing something odd with the carb tuning (Mikuni/UCAL BS29 ).
Going by the manual this is what I did -
-I set the pilot screw to 3 whole turns out(ant-clockwise) from fully closed.
-Started the bike(choke closed) and set idle to 1000 RPM.
-When I turn the pilot screw in (clockwise) the RPM goes up and at fully closed the RPM is about 2400+.
I would have expected the RPM to go down and the engine shutdown completely with the pilot closed all the way in. Any idea what is causing this? Is it an air leak issue?
Note that I can set the pilot to 3 turns out and idle to around 900 RPM and it starts up on first kick without choke and runs fine.
Thanks
-uv
Thanks
-uv
