- Thu Dec 20, 2018 12:59 pm
#80693
IMHO Having a bike lift makes the whole process easier.
As has been said remove things like exhaust, carb, primary, unbolt the gearbox and remove it and don’t forget to remove any wiring to the engine, I would also recommend draining the engine oil before taking it out of the frame.
And yes, take the head / cylinder off as well as it reduces the weight, also remove the piston form the con rod, put the crank at BTDC and stuff the cases with rag to protect the rod – easy to bend it if you leave the piston waggling around on the end of it !
Aim to have the minimum mass that you have to manhandle, and putting the bike onto a lift before starting work makes life a lot easier.
Good luck
Good luck
Previous bikes - far too many !!
