- Fri Jun 15, 2018 11:13 am
#8573
I have on to many occasions now gone to start the 535gt, and on pressing red switch no fuel pump, the fix has been easy joggle relays in and out and problem solved. I have now tightened up the male connections so the relays fit very tight and I found one relay was not clicking over cleanly and you could hear the contacts stuttering, so purchased a new relay and all is well now, I looked around and found on a well know auction web sight - MICRO RELAY 5 PIN 12V 20 AMP CHANGEOVER MINI 20 AMP CAR VAN BOAT MOTORCYCLE at £2.49 each, I purchased two of these number MRY9 and my bullet is running as normal on these, I will run them to test their longevity, these are much cheaper than original spare parts but not being electrical minded I wonder if their is an electrical guru in RE land who could comment on these, they appear to be the same and run ok?.
