- Thu May 10, 2018 12:15 pm
#8438
Afternoon all,
I'm stripping down my front end of my bullet 65 atm and have run into a problem. I have a fork spring that is stuck inside a main tube stanchion. The first spring just slid straight out but the second is causing me a headache. It's wedged in there very tightly, very tightly indeed. I've tried with a screwdriver to pull the spring out but the tension is so great it just springs back inside the stanchion. I've also tried giving the spring a gentle tap at the other end but to no avail. Any ideas on how to remove? Also whilst removing/ breaking down into the component parts each fork is missing the short spring but measuring the main spring the length is 21.5 inches is this correct? I thought I read somewhere that they were 20.5 inches in length.
Thanks for reading
Thanks for reading
