By Scalyback
#65715
[center]
Not being sure, I gave it 'a bit of a twist' and it seemed to work well, it is a piston and cylinder and the end is a screw cover that holds a metal plate, it works with the pressure of the piston, managing to squeeze the liquid past the end plate and it comes out under pressure and all creamy!.
I post a vid?
By PB1
#65717
My most favourite workshop manual phrase is "tap gently with a hide-faced mallet until it works free". I think we all know what that usually ends up meaning....
By Leon Novello
#65718
Screw it up tight until you can feel the threads starting to strip, then give it another full turn, then light a small fire under the bike and go down to the pub.
