- Sat Jan 14, 2017 5:04 pm
#7011
My 535, 14 reg 2000 miles, gives me a problem from time to time, sometimes when I'm wanting to take the bike out, turn the ignition on, no buz from the fuel pump, some times when I'm out on the bike, it will cut out, same problem, no buz from the fuel pump. It's the kill switch, by tapping the switch, eventually the pump buzzes. I've taken the switch apart a couple of times, cleaned the contacts with an electrics contact spray, and it does the trick. I can't get to the actual contact as its hidden and inaccessible. So, this may be a daft question, but does the team think it's a good idea to always turn the engine off using the kill switch, so as to keep the switch 'in use'
