- Fri Dec 23, 2016 5:39 pm
#6966
Can anybody help with the location of the bullet connector that the stray earth cable (grey/black) connects to that comes from the sidelight bulb of the headlamp of my 2002 Bullet. I removed the headlamp to upgrade the headlamp bulb and discovered a stray earth wire that I assume unattached itself as I removed the lamp. I'm at a loss to where it goes. If I turn on the ignition and switch on the sidelights nothing happens until I touch the cable to an earth so I assume that confirms it must be connected to an earth rather than left loose but I cannot find it. Any help would be much appreciated.
