- Fri Sep 23, 2016 9:16 am
#6730
Here comes the situation/problem: engine has normal ops temp. and idling is fine (on center stand after a ride), it idles with constant revs - nice, I am happy. Suddenly, after 40 to 50secs, there is a noise like "paff", revs decrease in a way that the engine hardly keeps running; then, may be 3 or 4 secs later, revs increase to the level before the "paff"! This mysterious decrease/encrease idling behaviour happens in a more or less regular period when leaving the bike on the stand; there are no external reasons such as playing with the throttle, and ignition, fuel pipe/filter, carb jets etc. are all ok (engine runs fine under all conditions, except he above). Do you think I have a problem with the float so that it comes to a lack of fuel (but why should this happen only during idle)? Any thoughts and/or experience? Thank you very much, Peter.
