- Sun Jul 03, 2016 8:50 am
#59734
Scotty, you need to be perfectly clear which bike model and brake you have - the 535 CGT has a Brembo 300mm, the Bullet/Classic is 280mm and although superficially similar, it is not the same. If you have overhang, which will prevent full braking pressure, you have an alignment issue. If you have fitted a knock-off CGT caliper to a 280mm rotor I would not expect it to align because (a) it is a knock-off and be (b) it is for a larger diameter disc.
