- Thu May 26, 2016 10:34 pm
#6302
Hi Bullet comrades
hope you can help me with this one. Bullet 500 kick-start 2003
* on compression stroke at BTDC
* base-plate turned clockwise to full stop (to base plate securing screw in leftmost slot position)
Points are already a fraction open; Turning base plate anticlockwise open points further to set 0.4mm.
A) is this right or should points actually close when turning anticlockwise?
I had a rattle in the timing case last week - only once; could this have something to do with it?
B) I tried to alter the position of the cam - took off the base plate and undid the Allen-key bolt; The cam moves freely forward but springs and auto-advance unit do not come with it - do I need the special tool for this? Is this the right approach anyway to this problem?
Thanks for your time - hope you can shine a light on this
