- Mon Nov 23, 2015 6:28 am
#5722
Hi guys. I have now received my new 535cc piston and steel conrod for my 1996 Classic from our hosts and am ready to place in my refurbished alloy barrel. The Accralite piston paperwork says I need to bore to 5.3-to-5.7 thou clearance. Various reports of seizing due to incorrect bore clearance have been noted, and in all cases this minimum is stated to be 6thou. I know this is minimally different from that stated by Accralite, but the costs of getting it right later are now too high (value of the rand has more than halved over the past 12 months so that, for example, my new conrod landed costs more than the cost of a new chinese scooter).
So question 1 is “what is the correct clearance?â€
The new conrod may be a different weight than the OEM alloy one (very likely) and the piston+rings etc are certainly heavier than the OEM 500cc one (OEM=513g and 535cc=541g).
So question 2 is “if the OEM crank+piston was balanced to ~65%, should I aim for a similar balance factor now�
Cheers, ChrisD
Cheers, ChrisD
