- Sat Jan 31, 2015 7:00 pm
#4630
I am planning some work on my gearbox ('89 350) as I believe the bronze bush between the layshaft and Kickstart shaft has failed. It may turn out that the other bush has failed too; if this is the case, will I have to remove and strip the entire box? How do I remove and replace it? I'm hoping to get away without removing the 'box from the frame.
