- Sat May 10, 2014 8:03 am
#3604
I'm a tad worried about fitting the new 612 crank as the shaft on the drive side will be a tight fit , the manual talks of using the crank sprocket with a inner distance piece to pull the crank through the 2 bearings , what does this distance piece look like and can I buy one , how much should it be pulled without binding up on the thrust washer . The timing side is in the manual said to be knocked with a wooden mallet which sounds very crude , I want the crank to be center with the same play on each thrust washer , this crank cost shit loads and I dont want to take crazy risks banging it with hammers , I'm loosing sleep over this , any help would be great .
