- Mon Mar 10, 2014 9:03 am
#3362
So... what would be the possible source of a whining noise from the top, front of my EFI? To give a bit of context, those of you who have heard an EFI starting will know about the fuel pump whine as it primes... well, the same-ish noise is coming from the top front end of my EFI when the bike is running - it doesn't sound like an engine noise at all. But it may be coming from there.
Possible sources - note these are my thoughts, none are actually obserede to be happening, just wondering if a whiney noise might come from these problems: leaking exhaust at the join between downpipe and head, slight leak of gas from head gasket, regulator/rectifier giving out, ignition coil dying?
Again, those of you with an EFI or that know the EFI layout will know where these bits are roughly located on the frame, so may know other sources of possible whines... Any advice on where to focus would be great. Its very annoying!
