- Thu Mar 06, 2014 11:37 pm
#33838
Reading it again it seems from the coil position access to the wiring is a bit limited. Sounds as if the coil has been moved at some point perhaps to aid cooling, and the wiring extended using non standard colours. The coil should be mounted on the frame top tube under the tank. Perhaps it is a non standard coil too big to fit there.
