- Tue Jul 23, 2013 12:58 pm
#2464
I have a350 bullet 1989, with a two wire alternator, to charge the battery, & provide lighting via the battery….
I am asking if a four wire alternator, can be used to charge the battery, and if yes, to ware each of the four wires attaches to the existing wiring harness….
The current voltage regulator & rectifier, is the old Indian 2 part system. I have a power box that has been on the shelf for the last few years, waiting for the Indian units to fail…. This could be used if this makes the conversion any easier..
The reason for the possible conversion from 2 to 4 wire is that the windings an the stator have been in close contact, and the windings have over heated, or the encapsulation around the windings is showing major signs of over heating… It still charges…
The problem started with odd sounds coming from the area of the alternator or n/s main bearings.
On strip down the stator nut and the 3 nuts holding the windings were found to be secure, but the stator and windings were showing signs of being in contact, as if the main bearing had dropped a few thou…… I split the crankcase, and the Indian main bearings replaced with European. On start-up after the rebuild all seems ok, but after about 25 miles, the odd sounds a back…
Could it be that the stator is “expanding†? I have not heard of this, has anyone any experience of this.
Any words of wisdom welcome Martin
