- Thu Jun 27, 2013 6:31 am
#2358
I'm not sure what they are called in the UK but out here we have the C5 which is unit construction without a kick starter, probably about a 2009 model. It is blowing a fuse that is located near the rear guard. I haven't seen it yet so I don't have a lot of info but I'm going to have to sort it. From what I can imagine it probably controls the fuel relay, fuel injector and the fuel pump. The only online diagram I have seen shows no fuse in this area only a main fuse in the main pos wire from the battery. I'm going to be stuck with this on Sat so any early info would be a help. Any C5 owners come across this problem?
