- Sun Jan 13, 2013 10:17 am
#21609
Looking at the wiring diagram again with your info in mind, it is all making more sense. Black battery lead should go to shiny bolt hole behind battery carrier (what is now a vet obvious frame earth) but nothing goes there. Instead black goes to starter (connected to engine, in turn resting in frame, making a poor earth??) and positive goes via solenoid to starter motor. What I can't understand is how things have worked for so long without a proper earth? Now... do I reinstate a new earth (using what gauge of cable) or leave things? The pictures in my service manual suggest a very different looking neg cable running to starter and my current starter neg following a different route (presumably to the earth point). To fix or not to fix...
