- Tue Dec 11, 2012 1:04 am
#1556
Does anybody have an inside measurement between the cast mounts on these frames. The spacers/thrust washers I've just recieved seem too wide, meaning I have to pump the frame apart nearly an inch to get the swing arm to fit. I can turn them down to suit if I have a measurement to go by. From what I can measure on an Indian frame it appears about correct without spreading the frame. Even a centre/centre measurement between the cast mounts would be close enough.
