- Thu Nov 15, 2012 6:03 am
#19505
Sorry to hear about your trouble, Ray. Sounds like an electrical fault in the ignition circuit, or a fuel problem. Unfortunately the Electra X has dodgy electrics, and on numerous occasions has has my bike developed the same kind of symptoms as yours.This has been due to: - loose yellow alternator wire in connector block above crankcase (three yellow wires in total), duff spark plug,loose HT lead,broken reg/rec, water in ignition switch, corroded connector in headlamp, flat battery. I think that more or less covers the ignition circuit problems I have encountered over the years, so check these. Also drain the fuel if it's old, clean fuel filter, strip carb and give it a good clean (not too difficult to do), and empty engine breather catch can of any white gunk and clean engine breather pipes. Good chance your bike will run sweet again after checking these.
