- Tue Aug 28, 2012 4:33 pm
#16683
Hi guys----------- well, here's the answer you've all been champing at the bit for}--------------To re-cap, I was cruising along at an indicated 60mph when, with absolutely NO warning whatsoever, the bike gave 2 v.loud backfires, the ignition went dead and I coasted to a halt at a local lay-by, with NO mechanical noises at all. The first, and easiest to test for is a spark----so out with the plug and NO SPARK !!.(Fuel related probs. tend to be either long, drawn-out affairs with repeated mis-firing or stuttering ( water in the fuel ) etc. OR}---- A sudden affair with the smell of petrol = a large leak/ pipe come off. )---There had been none of these indicators. At this time all the other electrics were ok so the single fuse was ok (Confirmed by visual check)--- Off came the points cover, tweak them with a screwdriver (with the ign. ON, of course !)--------- NO spark. Swap plug for NEW ONE ---NO SPARK. Using the test wire on the HT coil, clip one end to the LT input and "splash" the free end against an earth = A "CRACKLE" of ELECTRICITY. Now clip to the LT output side and "splash" to earth -------- NO crackle !!! ANSWER = Open circuit on the LT windings within the HT coil. And, as I don't normally carry a spare HT coil, now was the moment to use that mobile phone (points to ALL who mentioned that one !! )-------Therefore, in strict order of posting, the winner is }-----------TIM G, with MIDGE a close second. So TIM G, you get a night out with my missus at a Harley HOG meeting of your choice, whilst MIDGE--you get TWO nights out with my -************ etc, etc. You get the idea ?? Many thanks to you all for entering into the spirit of this little escapade. It just goes to show that it's not that easy trying to do diagnostics within a forum structure. Finally----that sun in the West ??? Well--------it looked so pretty I thought I'd just mention it !!! (Comes under the heading of a "Red Herring"). Now I'm definitely off to the pub----to see a man about a washing machine !!! Bye all--------.
