- Sun Apr 01, 2012 9:08 am
#11081
Hello No3 Phew!! All this "on any Sunday" ??------------you mentioned in your first posting that the carb had a "blow-dry" What are you using for this ??---------to properly blow these drillings you must use compresed air at around 100psi. A puff with your lungs just aint up to it. BACK_BLOW ie against the directon of flow then prove each separate drilling with a squirt of carb-cleaner. It's time consuming and tedious but needs to be done. Then do the same to all the jets----check the emulsion tube cross-drillings are clear and the clamp-washer at the botom is held firmly in place by the main jet. This is the British Bulldog Spirit in action here ( Includes our mates in Oz by "familly" association). I suppose you could buy another bike and swap the No. plates ? Only joking !! But still----------------hmmm-----------
