- Sat May 12, 2012 8:55 pm
#447
Fitted the stock torpedo silencer back on the bullet today to replace the aftermarket custom pipe on there.
Tried to fire it up to hear how it sounded with the standard pipe, non start, whipped out the plug, getting fuel, checked for spark, thought I got a weak spark one one attempt but subsequent tries yielded nothing.
Tried a fresh plug I had, (an iridium, wrong size but just for spark), nothing.
Now electrics are not my strong point but am I right in assuming that I should get a 12V feed across the + and - of the LT connections to the coil with the ignition on?
Currently i'm getting nothing on them, ignition on and rotating kickstarter or not.
Been wracking my brains trying to think what i've disturbed electrically, I re-routed the clutch cable as it wasn't running cleanly, which was near the alternator wires but they're clean and well connected.
The only other thing is the 2 wire plug from the electronic ignition box to the magnetic breaker on the points plate, unplugged to re-route and neaten, otherwise nothing electrical touched.
Any help or ideas would be greatly appreciated, thanks
