- Sat Mar 03, 2012 4:46 pm
#115
I have a lUCAS horn on above bike. I think it is HF1441 as I have seen a similar horn on ebay as to style. It conisist of what looks like basically two halves, a clamp to keep it together and a 'floating' like disc with two brass nuts on a bolt through thehorn. There are no working parts inside and I wonder if anyone knows how this can be repaired. It ais a while since I took it apart and maybe going a bit wooly in terms of how it is constructed. I have dummy cables running to it but the actiual working horn is under the seat. All electric cables to the dummy horn give a circuit but I don't know what should be inside the horn and wonderred if anyone has fitted a 6 volt 'pattern'part inside such a mechanism. I am basically have worked on the bike and used it for a couple of years thinking can I finish it off although it is only a cosmetic change. Anyway any help appreciated. Thanks and now the sun's out enjoy the summer riding to come. Hugh
