By vic
#149
hi all still working on my 350 2004 bullet
could any one tell me what threads are on my 2004 bullet its from india and i have converted alot over to metric
problem i have got i bought a stainlees rear brake rod and ime at max adjustment old one has been threaded more and i need to tap it more
took rear wheel off and will be putting new hitchcocks shoes in (costing me a fortune )
regards all
vic
By simon
#10339
Oh if it's imperial it will be cycle thread 26tpi 60 degree pitch.
#10340
Hi Vic---- if I'm reading this correctly your rear brake adjuster, on this new brake rod, has gone all the way up to the end of the thread ?? Try putting a short steel sleeve ( say 2" ) in front of the adjuster nut. Simples !! No threading needed. I'm assuming that all is OK with the brake lining and the brake arm is in it's correct position ??
