By Kentish Man
#102387
HiYa all,
My 2007 Electra X, the decompressor lever broke in in Lefthand plastic switchgear. I'm told this is common as its normally used to operate a choke on a carburettor. so I bought a new switchgear, Genuine Minda .I tried to fit the cable and it looks like I am missing a ferrule or a spacer?.
By Daiwiskers
#102403
If possible I would use a separate lever for the decompressor the type fitted to nearly all singles in the 50s and 60s
Hope this help's Dai
Kentish Man wrote:
Sun Aug 07, 2022 6:55 pm
HiYa all,
Yes, I just checked on my bike's Minda setup, which has the plastic lever for the decompressor. There is supposed to be a separate split ferrule on the end of the cable. If the cable broke, it probably fell out at the time because it's a loose fit in the switchgear mount.
Here you go, it's part #10:
https://www.hitchcocksmotorcycles.com/p ... osition-10
My bike has the throttle on the other handlebar ;)
Here’s the one on my bike’s decompressor cable:
